Surges at idle | Ford Explorer Forums
Surges at idle
brycermeyer
Bremerton, Washington
1994 Explorer
At idle with the A/C on the engine will surge from 700 rpm to around 1500 rpm apx. every 6 seconds for about 1 second. With the A/C off there is no surge.
Sounds like a vacuum leak.
I'd check the A/C system. Could be that the system is engaging the compressor too heavily, which then causes a heavier load than the engine was expecting, so the idle speed surges to keep the engine from stalling, and it just repeats.
It could be that the A/C system is low on oil, refrigerant, both oil and refrigerant, or just that the compressor is worn and the A/C clutch is just not working right.
Might need anything from a system recharge to a new compressor, or a whole new system if it's contaminated.
Hopefully it's a vacuum leak or something minor, but if it ONLY happens with the A/C on, it's likely the compressor or at least something A/C related.
