frogman
- February 28, 2004
- Detroit Lakes, MN
- '95 XLT 4x4
Greetings All-
So, I was hearing a little squeaking coming from underneath when the truck was driving at a slow speed and also wanted to get it in for an alignment check before I put a new set of tires on, so into my local Ford dealer it went. A phone call later I hear the news: 2 upper and a lower ball joint, tie rod ends, and the U-joints are bad (the squeak) but the U-joints are not replaceable so we will need to get a rebuilt drive shaft...all for only $1200.
Basically in shock, I bring it to a local neighborhood mechanic (recommended to me) for a second opinion. He confirms everything. Now, the ball joints surprise me as when I was in for an alignment for the current set of tires, I had to replace them (2 lower and 1 upper), but this was about 48,000 miles ago - what is the life expectancy on them?
Anyway, I know a bunch of you guys will replace the ball joints yourself, but I am not so inclined to do this. Are these $$ values in line of what it should cost??
Thanks.
Thanks.
