sway-bar bushes? | Ford Explorer Forums
sway-bar bushes?
OZexplore
coffs harbour n.s.w. Australia
98xlt
i need to replace the front sway-bar bushes but can only get rubber ones (oem) i want the neoprene ones so will need to get them from the usa
are the standard sway-bars in the usa 34 mm in diametre that is about 1 3/8 inch thick.
http://www.explorerexpress.com
If you call them, make sure you specify bushings, not bushes. You get a Jeb and George W, and chances are they won't be much help with your front sway bar.
very funny but we call them bushes
and you can keep your bushes
i need 1 right & 1 left but you appear to only have 2 for the right
as there both for the right if i put one on the left wont that make it steer funny
Just a word of caution. If you put both bushes on the right you will have an uncontrolable veh. that will run over liberals & gays as it brakes for illegal aliens.
LMAO!!!! :D :D
i still haven't found out how thick the sway-bar is ,i really need to know as to get them from the usa it is over $120 and i guess you would be happy to give me those other bushes for nothing.
Your probably going to have to measure your own sway bar to find the size.
I dont know why they would be, but US bars may be different.
we get upgraded suspension to help stop body roll & stiffen it up
i have measured it 34mm i need to know the diametre of the std bar on the usa models
before i fork out us$120 to import them
i'd ask john v.
hes the guy from explorer express and would be able to help you.
