Sway Bar bushing | Ford Explorer Forums
Sway Bar bushing
Damienmore
Charlotte, North Carolina
2000 Explorer Limited 4wd
While I was cleaning my wheel wells I noticed that the bushing on my front right side was completely destroyed, does anyone know what the proper bushing size that I should get is? There are 27-34 mm bushings on auto zone's site and they all say they fit the truck so I don't knwo which to get, and does anyone know what would make a new sway bar bushing do this in just a few months
Very common blown out sway bar END LINK bushings. Definitely aftermarket , but far stronger hardware than stock. Use a crescent wrench to measure BOLT diameter, not the center sleeve. Bushings can be replaced, but it may be easier and less expensive to replace both sides with new Moog K700542 end links with much more durable polyurethane bushings.
eBay: $8.63 shipped Moog K700542 endlink | Ford Explorer and Ranger Foru
Refresh My Memory - 2002 Front Swaybar End Links | Ford Explorer and Ranger Forums - Serious Explorations
Damien, read through the "Refresh my memory..." citation in sws's post. Tells you all you need to know about doing end link bushings. Use the Moog end link and Energy Suspension bushings. Highly recommended. I think they are Moog #7275 front end links and ES #9.8103 High Performance bushing. Do both sides while you're at it. (... and put the end link bolt in from the top.. heh)
