Sway bar links and odd rubbing | Ford Explorer Forums
HiImBrian
St. Petersburg, Florida
2003 Explorer Eddie Bauer
I finally got around to changing out my shot sway bar links. I hadn't realized just how bad they were...
While I was down there I noticed some scrapes where the wheel hub assembly was rubbing on the lower arm.... What do you guys make of this?
I didn't check the other side, but will later this afternoon...
Mine has the weird rubbing too I think there stops for the steering and with the lift it's at a different angle and the "ball" lookin thing dont go into the "cup" part and it just rubs, also I can pull the front end down by turning the wheel all the way, I think this causes it
Normal. Appears to be steering stops doing their job. Use heavy waterproof grease on them.
Also, don't overtighten the rubber Moog end link bushings. I replaced mine with ES bushings.
glad to know my ex wasnt the only one doing this
