Synthetic in a 01 Explorer | Ford Explorer Forums
horseplay01
NC
2001 Explorer Sport
I have a 2001 Explorer Sport that has 50,000 miles. Is this to many miles to start using Synthetic? I use Mobil 1 in my Mustang and was thinking of switching the Explorer from Havoline 5W-30 to Amsoil 5W-30 with an Amsoil filter.
Thanks!
Definately not too many miles.
One thing you may want to do to ease the car into the Synthetic is to run a couple of oil changes worth of a Synthetic Blend (1/2 Synthetic, 1/2 Regular).
I do this just because the Synthetic will end up cleaning out a lot of gunk in the engine that has built up from standard dino. If you change your oil regularly and it always comes out fairly clean, this shouldn't be a big deal, but I personally feel its better to ease the engine into it. I am running Synthetic in my X with about 85K and haven't had any problems due to the oil (started using Synth about 5K ago).
Just keep an eye out for leaks. With 50K on the clock, none of the seals should be worn out, but better to be safe then sorry, you know?
Mix the oils? I didn't know you could do that.
There is simply no reason to do this. Just drain the oil and change the filter, and refill with synthetic.
Go for it.....
horseplay, I wouldn't personally mix it 1/2 and 1/2, but you can buy oil that is already blended 1/2 and 1/2. I used to use Castol Syntec Blend in my past Rangers and what.
Aldive, you are correct, you don't NEED to do this, but by going straight to Synthetic, if there is a ton of old oil buildup, the Synthetic will clear it out quicker than a Synthetic Blend. If you have a lot of buildup and the sludge comes in all at once, it can clog oil lines and kill the car (talking from experience here). Also, a lot of times the reason they don't recommend going to Synthetic on higher mileage engines is because the seals get old and shrink some. Regular Dino fills in the gaps often times and if you run a straight synth, it can clear this out and you can start having seals leak (again, speaking from experience here). So, by running a blend, it will not wear away at the sludge as fast and may reveal a problem to you before it gets too big to be a problem.
Honestly, if you have under 100k on the clock, you shouldn't have ANY problem running a Straight Synth right off the bat, but I just personally would rather ease into it, saves you a few bucks too when you're doing the oil change.
No one has to do this, but its my routine, I've even done it on brand new cars when I was going to switch to Synth. But, every person has had a different experience with their cars and that affects their outlook on this kind of stuff. Killing an engine switching to Synth too fast has caused me to be more careful with it (of course the car that I had problems with Synth on was a very badly Treated Toyota Pickup with about 100k on the clock, your engine is in FAR better condition so many of the issues I had you won't have)
Good luck, and you will love the feeling of having synth in your engine, I actually noticed a slight seat of the pants difference (mostly in how quick the engine would rev up, but it was very very very minor, probably wouldn't even register on a Dyno or anything).
So, am I better going to a Synthetic Blend first. If so what brand should I use?
Thanks again for the help!!!!!
My prefernce would be to go to a Synthetic Blend first, you may not have to, but it also won't hurt anything to do so.
I personally used Castrol Syntec Blend. Just about every major oil manufacturer that sells Synthetic Oil also sells a Synthetic Blend, so the choise is up to you. I'm sure others will have their suggestions.
Personally, I have always gone with Kendall, again due to some past experiences, but the choice is up to you. For the most part, oil is oil, but I would stay away from Pennzoil.
Good luck =).
horseplay01 said:
So, am I better going to a Synthetic Blend first. If so what brand should I use?QUOTE]
If you want to waste your money do it.
The amount of synthetic in a "blend" is not a fixed number and is usually very small.
