T- Case gone wild | Ford Explorer Forums
T- Case gone wild
tcaser
Explorer 97 limited
Want to start by saying: thanks to all for the useful information and tip's posted on this site. this is my first time here and i found out about this site after a dazzling 3 months, where no one were able to find out from where is the thumping sound coming from , on my 97 limited Explorer.
Finally today the FORD dealer guessed it was coming from the T-case (magnetic clutch is acting up). estimated 4,000.00 parts + 4 Hours labor + tax = problem solved, what the F***. is that realistic?
let get back few week. I disconnected the power to the T-case and took it for a drive test, still thumping. Then I removed the shaft that connects the T-case with the front axel, still thumping.
the sound is like smacking metal against metal with a kick feeling to it, it mostly occurs when accelerating or going up hills basically putting some pressure on the engine.
Long story short, does any one know what type of T-case installed on my car as I couldn’t find the part # nor any tags there??????
Thanks for your help in advance guys and I really enjoyed the useful information posted here.
If you have the 4.0L engine (you didn't say) then the TCase is a Borg Warner 4405 Control Trac. The thumping is a symptom of a common failure mode for this TC. I would look into getting a rebuilt TC from a good aftermarket shop before I would spend >$ 4k at the dealer.
More info:
http://www.explorerforum.com/forums/showthread.php?t=170068&highlight=transfer+case
http://www.explorerforum.com/forums//showthread.php?t=182071
http://www.explorerforum.com/forums/showthread.php?t=147696&highlight=4405
Thanks Dogfriend.
Yes it is a 4.0L and I have already foud a rebuilt T-Case for 700.00 CN.
Hopefuly this will solve it.
you said in Canadian money, where in Canada are you ?
might be able to get a used one sent up from Vancouver
Coquitlam is only 1/2 hours away from vancouver,I can pick it up any time if you now of someone who have this part, please let me know .
I appreciate the help
