V8-X
- November 6, 2002
- Edgewater, CO
- 02 F-150 S.C. Lariat FX4
1999 X 5.0 AWD w/AT
Let me just state the only mod I have is a drop in K&N air filter. Otherwise the radio and all parts are stock with no modifications.
First off it seems as though I have a problem with my Battery, Alternator or charging system. I have just replaced my Battery & Alternator 6 months to a year ago with OEM parts.
I have noticed that the X's Battery gauge will drop in voltage when I am not accelerating. When the X is running and in Park, all is okay and the gauge is right in the middle. Once I drop it into Reverse or Drive, the battery gauge drops down to about 3/4 of the way to the middle. When I run my lights, radio and heater, this drop is even worse. At this time the lights dim and the gauge is about 1/2 the way to the middle. This is while I am stopped in gear, but once I accelerate the battery gauge goes back to the middle of the gauge.
2nd issue related to the Tach and performance is a lot harder for me to explain.
When I am accelerating in 3rd gear the tach seems to get stuck at about 2200RPMs then it will drop to about 1800RPMs. This is all while accelerating and not letting off the gas, and it does not seem to shift into 4th and it's not the TC locking up which is causing the RPM drop. It seems as though the engine just loses power all of a sudden. This drop in RPM's also includes a deep tone type of moan & driveline noise like the X is in to high of a gear.
Now there are times when the X does shift into 4th or the TC locks up and this same situtation occurs. Which when it does shift or lock up, it's like the shift/lock up was to soon and the tranny is in to high of a gear.
Lastly, I get a loud whirring sound from the engine bay/front end. To me it sounds like the MAF/MAS or something with the intake is whirring. This is when accelerating or decelerating at slow speeds, as I am unable to here it when going over 30MPH. I have already replaced the IAC & TPS. Would this be more likely the intake or hubs, from my searches it could be either.
Is there the possibility that these are all related. Could the MAS/MAF be working incorrectly, which causes the erratic RPM problem, early shift points and the whirr.
Last time I got the CEL was 1 1/2yrs ago when I had a bad #4 plug. Since then I've had this problem and the CEL has never come back on.
Replaced: TPS, IAC, all 4 O2's, All 8 plugs & wires, EGR, T-Stat, Fuel Filter, FPR, Air Filter, Battery, Belt & Alternator. The MAS/MAF has been cleaned twice, Once by myself and once by Ford. Neither time did this cleaning the MAS/MAf help, and none of the parts replaced have fixed the problem.
Any and all suggestions would help, as this problem seems to keep getting worse and no one has been able to find the problem. (Ford Service Center, Independent Shop or myself)
