Tach guage dying? | Ford Explorer Forums
Tach guage dying?
ruzztec
McCreary County,KY
92 XLT 4.0/99 XLT 4.0
What has seemed to become more frequent, my tach needle will jump between a 500rpm range 1500 -2000 usually and then sort it self out and stay at 2000. then do it again later. Yesterday I was going 20 mph and the tach went to zero. I freaked out thinkin my engine was dead. Nope just the gauge. Now iv never messed with the tach but i presume i should check around the tranny? or does that cable just control the speedo? Any clues?
check the crank position sensor i think the computer uses signal from the CPS to get the rpm
My tach is stuck at 3500 RPM. I though the tach was run from the ignition coil (or at least on my old car it was like that)
what exactly would i check for? i mean would a loose connection or faulty cps not throw a check engine light?
