Tach Wire or Fuel-Injector Wire for Remote Starter Installation | Ford Explorer Forums
msmith65
Dallas
'93 XLT
This is a '93 Ex 2WD with pushrod V6 and A4LD.
The ProStart 2300 calls for a "tach wire" to be tapped. I located a tan/yellow wire underdash that puts out AC current as it's supposed to, but the voltage is under spec and doesn't seem to be enough to interrupt the start circuit.
Unfortunately this seems to be the only tach wire under the dash, according to the Haynes manuals.
The alternative instructions ("Tach Learning System," PDF p. 3) call for tapping the fuel-injector wire, which is among the "wires off the fuel injector.... Use the wire opposite of the common wire."
I'm at a loss to locate that wire.
Can someone help?
(I asked the dealer for tech help, but they're cold to supporting a second installation unless you buy another unit. Seriously.)
I got my Tach wire from the instrument cluster. This was a while ago as I don't remember the color of the wire.
I hope this can help you out.
1993 Ford Explorer Security Information
Constant 12V+ Yellow Ignition Switch Harness
Starter Red/Light Blue Ignition Switch Harness
Ignition Red/Light Green Ignition Switch Harness
Ignition 2 Black/Green Ignition Switch Harness
Accessory Gray/Yellow Ignition Switch Harness
Tach Tan/Yellow Coil
Neutral Safety Wire Not Grounding OEM Switch opens Starter Circuit
Brake Switch Light Green Brake Switch
Trunk Pin n/a Works with Dome Light
Parking Lights Brown Light Switch or Harness go THRU Firewall
Head Lamp Red/Yellow (+) Light Switch
Hood Pin n/a
Factory Disarm Dark Green/Purple (-) Driver's Kick Panel
Door Trigger Black/Light Blue Light Switch or Kick Panel
Door Lock Pink/Yellow Driver's Kick Reverse Polarity
Door Unlock Pink/Light Green W/Keyless Entry Negative Trigger Driver's Rear Quarter
Horn Wire Yellow/Light Green (-) Right of Steering Column
Windows Up LF=Red/Yellow, RF=Tan/Blue, LR=Gray/Orange, RR=Red/Black
Windows Down LF=Yellow/Red, RF=White/Yellow, LR=Yellow/Blue, RR=Yellow/Black
Yup, that's the wire (tan/yellow). I tried to get the device to pick up on its signal, but it wouldn't interrupt the starter circuit.
Maybe I was exhausted after all the wiring and didn't do the procedure correctly.
I'll try again.
normally with a remote starter you put i on a ingition wire.
im not sure which one, and the tach is hooked up to the iginition.
you should be able to find a wire to tap into thats adaquite enough.
It's gotta be connected to the tach wire so it doesn't keep trying to start. The tach wire is at the ECU as well as the coil.
If you have a tach in your cluster then you can hook it up there. There is obviously a tach signal going to the gauge.
