Tc issue will engage 4hi by pliers | Ford Explorer Forums
semperfi0306
kansas city, mo
1997 explorer
hey i got a problem with my explorer, ive been trying to find a thread on here about getting it out of 4low but it doesnt seem i can find the answer im looking for. My issue is when the tc is in 4 low it works and does everything it needs to, when i put it in nuetral and apply the brake and hit 4 hi it just makes a grinding/buzzing noise, then if you put it in drive or reverse the noise just gets louder, so i took off the electric motor and shifted it by pliers, tc works just fine, but it seems the electric motor is doing what it should as well, the little motor is consistant through its motion and it was replaced just recently. Basically my question : is there somewhere that i can adjust the electirc shift motor, or the tc, cause im almost getting the hint that it needs just a hare more movement to be fully engaged, any ideas????
You may want to check the shift fork bushings.
