sinbad30
- February 27, 2007
- 97 explorerxlt
transfer case stuck in neutral
97 explorer 4.0 sohc. loaned to the girl. she proceeded to get stuck in snowbank. She started switching from auto to high to low.Did so not in a nice way. Drove truck to store. Went to leave wouldnt move. Went to retrive truck. Had towed to driveway. Next day started and moved but only in low range. tried changing switch. Still in low. Changed shift motor. Still in low. drove down the street went to back up,wouldn't move. towed back to drivewav. Code 1838. changed shift relay. still won't move. trans works and shifts(you can watch the output shaft speeds. shifted fine in low range for a little while. Stuck in neutral? only one more relay lefT! Has anyone had this happen? is the T- case junk? any and all help would be greatly appreciated!
