blongo
- March 17, 2005
- San Gabriel, CA
- 98 XLT 4x4
In the last week or so my 98 Explorer SOHC has developed a couple of strange problems that may be related.
Under load such as accelerating on the freeway, the temperature gauge quickly will go from normal to full hot within about 10 seconds. Once I quit accelerating and maintain constant speed, the gauge quickly returns to normal - again in about 10 seconds. This problem has seemed to get worse in the last few days. It seems to show hotter quicker and under less load.
I can't tell if the engine is actually getting hotter, or if it is just something being shown on the gauge.
Radiator is full and appears clean, and I'm not losing coolant.
Overall engine power seems to be down somewhat.
The other problem that started at about the same time is when I come to a stop, the idle speed remains fairly high (about 1200-1500) for several seconds after stopping. This makes coming to a stop difficult as the transmission is still being driven by the engine and downshifting is affected as you might expect. I've replaced the IAC and that didn't help this symptom.
Could these symptoms all be related? Any ideas?
Thanks in advance!
Thanks in advance!
