Foggman
- February 20, 2005
- Virginia Beach, VA
- 1994 2dr Sport
I have a '94 X with an electric cooling fan with one of those temp. probes that goes through the radiator fins. I am not comfortable with its reliability (it seems to be inconsistent with when it turns on) Does anyone know of any way other than the probe way to get coolant temps to a relay that would turn a fan on?
I was thinking about doing some testing on the two temp guages on the intake mainfold right behind the thermostat tube. I was also thiking about using a home made type that would involve cutting the heater hose and putting in a "T" fitting but from what I understand if you dont have the heater turned on the coolant will just fill up in the hose and not circulate. DOes that make sense?
