ddenton749
- March 27, 2002
- Kennett Square, PA
- '93 XLT
1993, 4.0L, Auto, 4WD. This problem started about a month ago. When driving at a normal steady cruise, the temperature rises up to about the “A” in “NORMAL”, stays there for only a second, then drops back down to below the “N”. The needle will stay at the low end for a minute or two and then rise back up to the “A”, where it stays for a second, then drops back down below the end. It continues to cycle this way and never reaches equilibrium.
I know it isn’t a bad sending unit, gauge, etc. because I can feel the difference in the air temperature coming out of the vents when the heat is on.
In the second week of February I replaced the water pump because it was leaking. I also replaced the thermostat, the serpentine belt, and all of the hoses. The temperature fluctuations started around the end of January, before I replaced the water pump.
Any ideas?
At no time has the temperature gone above the “A”, but its still winter and I’m worried what will happen once the weather turns warm again. I don’t spend a lot of time idling, but the gauge seems to stay at the low end at idle.
Any ideas?
