Drg racr
- November 18, 2006
- Dublin, Indiana
- 2001 Explorer XLT 2WD
This forum has saved me some serious cash in the past few days. I have narrowed down my 4x4 problem down to the auto hubs, so I'm going to order the manual kit from Summit Racing. I used Sea Foam in the motor, and some of the spark knock has gone away. I also found my trans modulator was sucking fluid into the motor, so I fixed that this morning using your directions (accessing thru the floor plate). Next I need to fix the pass side trailing arm bushings.
My 94 XLT has 122,000 miles on it. Any other things I should look for?
I replaced my EGr valve today too. It was throwing a code that indicated it was bad. But, my Check Engine light is still on. I unplugged the battery for a few minutes, should I have let it sit longer? It's still a little sluggish on acceleration too. It almost feels like it surges sometimes.
You guys are a real life-saver. Thanks!
