The brake proportioning valve connector broke off. | Ford Explorer Forums
Malk67
Location
Salisbury
North Carolina
96 Aerostar XLT 3.0L
OK so today I'm replacing the master cylinder on my van and when I went to disconnect the wire from the switch in the proportioning valve the damn thing broke.
Does any one know where to get said piece of plastic crap or will I end up having to replace the entire proportioning valve?
Thank you in advance.
It broke where the threaded area starts.
You have a few choices:
1. Leave it the way it is if it's not leaking. You won't have RABS.
2. Purchase a new part from the link in the previous post. It's a job to replace it.
3. Try to find one at a junkyard cheap.
I bought one years ago because mine had a short, but I never got around to replacing it because it's a big job. There's limited access plus you have to bleed the whole brake system.
Well I managed to zip tie it into place so the ABS light is out.
But after bleeding the system I realized that my initial fear was true. I need to replace the booster.
It seems to be.
Rear ABS Light came on with it off. It went out after it was reconnected.
