The "Bunny" VS. 91 EXP Tranny | Ford Explorer Forums
D M Dickson
N. Charleston South Carolina
91 Explorer 2 WD
My 91 Exp had a tranny leak and was ran completely dry of trans fluid. I had the truck towed home and dropped the pan and put in a new filter and 5-6 qts of fluid. Low and behold the tranny is working fine, it shifts good thru all gears and does not slip at all, cold or hot starts. I did find metal particals in the filter I took out. Is the tranny in need of a change out or is it possible a rebuild could be done or should I just drive it and see if it will out last the "Bunny"? The trans has been rebuilt previously and I don't know how many miles are on it. Thx for any comments.
