Stinger357
- November 8, 2010
- Plano, Texas
- 1997 Ford Explorer Eddie
I sunk 1500 dollars in getting my truck fixed. Front end aligment and plugs and wires done correctly this time, the rattling under the car has been fixed. got the ac unit fixed. and upper and lower intake manifolds rebuild. seeems a little better now. But the bad news is the compression test found that 2 cylinders where not up to snuff they are not producing compression like they should. So the mechanic said dump the truck asap. He also said to fix that is a complete engine rebuild, which for a 3000 dollars truck aint worth it. So I am going to drive the wheels off it until it dies. Is there a better way to fix 2 cylinders rings without having to rebuild the entire engine? I made a bad trade for this truck but at least it gets be from point a to b. Any suggestions on what I can do to make it last 1 to 2 years more?
Thanks,
Thanks,
