The MAXIMUM safiest tire size with the stock '91s front axle? | Ford Explorer Forums
Shurup
Edmonton, AB, Canada
91 XL
What is the maximum safiest tire size I can run with my stock front axle (91 explorer) without killing my balljoints, bearings, bla, bla, bla...
what I mean I want to have the maximum tires possible and I don't want to do and SAS.
Trimming, lifting, etc. are the other questions, so please don't discuus them here. thanks
235/75r15's
i have
31x10.5x15 on my 92 no rubbing. It does fill the wheel well.
I've been told they won't fit on the explorer
Oh by the way this is set #3
FRONT
REAR
Hope this helps
Aha the 8 lugnut Explorer.. Where did you get those caps? I like them.
like them
They came off an Explorer I think it was A 93.
AS for the ball joints I've only had to do one set.
in 170K. It was done when i hit 100K, so i'm guessing i still have a little more life in them.
AS for the front wheel bearings I change them every brake job. For the extra 30 bucks I think it's cheap ins.
HOpe this helps
those caps only came on 91 explorers. he asked the safest tire size, any tire size larger then stock will not be as safe as stock. Also most tire retailers will not install tires larger then stock on an explorer.
I want those caps!! Could I order them from ford?
i've seen
them on about 12 or so explorers around here.
I bet you can get them from ford. But you will get sticker shock
