gwynn1975
- April 18, 2014
- Williston, ND
- 2004 Explorer
I have a 2004 Explorer 4.0 SOHC V6 that I have been dumping a ton of money into, and my problem is still not solved.
My Service Engine Soon light came on and I noticed a rough idle and "shaking" while in "drive" and at a stop.
I had the mechanic run the codes, and it was showing misfires and running lean.
He has changed the spark plugs, spark plug wires, and did a vacuum leak smoke test. After I paid for all that, it is still running rough with a shake at a stop and idle.
The mechanic says that he thinks my timing chain has "jumped" and he will charge me $2800 to fix it.
Here's my dilemma:
It only idles rough at times. (Not a constant)
I have done a search on here, and everything that I see doesn't ever mention the timing chain.
I cleaned my MAF and it seems to run a little bit smoother, but it is still throwing codes and running rough. In my search, I have also read that the 2004 does not have a IAF.
One other thing that I noticed today, was if I really give it some throttle going down the road, I hear a strange noise that seems to be coming from where my MAF is located, but of course, I can't tell exactly, because I'm driving down the road when I hear the noise.
Please help. I really don't want to pay the mechanic all that money, when it might not fix my problem.
Thanks in advance.
Here's my dilemma:
Thanks in advance.
