mstyles
- April 10, 2008
- Atlanta
- 2005 Explorer
OK...First of all....Good to be part of the forum and thank you in advance for any help you might have to offer. So here's the deal...
2005 Ford Explorer
Problem #1:
The truck has a low idle speed that I can not figure out. When sitting at idle is shakes to a point that it will wake my kids in the back seat. I noticed a break in the throttle body so I replaced the entire thing...still no luck. I have also searched for vacuum leaks and I have not seen anything yet. Is there something that I am missing? Is there a way to control the idle? Other that than the vehicle runs fine.
Problem #2:
The rear A/C vents on the back of the center console dont work. It sounds like there is a rear barn door that opens when you hit the rear switch but still no air. Any suggestions? I am a little reluctant to see if there is a problem in the center console until I hear back on this. I know that GM decided in 2005 that they were going to put an airbag sensor in the center console. If you tip it then it thinks that you rolled your vehicle and deploys your airbags!! Incase you were wondering....I know this because I did it to my 2006 Tahoe while installing a sound system.....pissed off was an understatement!!
Anyway...thanks again if anyone can help!!!
2005 Ford Explorer
Problem #1:
Problem #2:
