thermostat help | Ford Explorer Forums
thermostat help
Xeek
Virginia Beach, VA
1991 xlt
ive read you only needed to take off 2 bolts to get the housing off. but for some reason i have 3? its impossible to get in there to even get the thing
#1 is at top-right, #2 is not pictured hiding under housing
#3 is behind that black wire which has no slack and cant move, from the top the alternator gets in the way
im trying to get some more tools at the moment, but has anyone had experience with this 3rd bolt?
i know it holds it on cuz i can spin the housing and it rotates off that bolt
Take the belt tensioner off
did you clear the ecm after?
and drive for atleast 15 min
you need it to relearn but if it came on right away then there is probably something wrong.I'm not real good with codes so maybe someone can point you in the right direction.
Maybe the plug is not making a good connection or ground,idk really kno.did it warm all the way up
you know what, i dont think its the right sensor.
looks like theres more thread and the tip is longer/narrower
maybe thats why i could see a little thread sticking out when it was in as tight as i could get it.
couldnt tell with the old one cuz it was so dirty
Maybe. Its tappered so it might not go in as far becarful not to crack the intake.reset and put the old one back in and see if the code changes and let it warm up,if u can't tell by dash,the top rad hose will get real hot when its warm
