Corik
- July 15, 2011
- CA
- Explorer '91 XLT 4x4 A4LD
Hey guys, I've had the suspicion that my thermostat was bad.
I've was told that one way you can test is to hold the top radiator hose and if it warms up slowly rather than suddenly then the thermostat is bad/stuck open.
I did this and it reacted this way.
I bought a Motorcraft thermostat, and after some cussing and time I got the old thermostat out...but it isn't stuck open.
I even tested it in a pot of hot water. it opens fine and closes again.
The only thing i noticed is that there is a little hole on the side. The Motorcraft has the same hole; however, it has a little bead there like it wouldn't let as much through.
here is a pic of the old...
so should I just put the old one back on?
