These came in my Luk clutch kit | Ford Explorer Forums
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
And I don't know what they are for. Don't want to remember too late. Ones a little O-Ring, the other is a flat metal ring.
Bag says "Retaining Ring and Seal"
Does the little one go in the line coupling?
It's about that size. The metal ring is almost a spring, except the two metal pieces lay flat.
The retaining ring and o-ring are for the throw-out bearing.
Only used if you are re-using the old throw-out bearing.
If you bought a complete slave you can just shelve those for next slave replacement.
Here's an example of a slave without the bearing:
https://www.blunttech.com/products?prod_category=I3
[MENTION=226817]Number4[/MENTION]
Thanks [MENTION=242785]FR-425[/MENTION], I put a new slave on as well, so these parts will just get filed.
:thumbsup:
