Wray-Wray
- September 3, 2008
- North Tonawanda NY
- 99 Moutaineer 5.0L
this is going to be interesting to try to describe but here i go.....
ok i have 99 mountaineer 5.0 AWD
The motor has been leaning out at anything above 3600rpms
my fuel filter mite have 25-32k on it
i run injector cleaner threw it once a month like clock work
did Lucas tune up in a bottle like 2 k ago
plugs are 35k old
wires are 35k old
pcv valve is 1k old at most and boot around it is perfect
all the rubber lines are ok
I had codes PO171 and PO174 read on my computer
171 is bank 1 running lean
174 is bank 2 running lean
After cleaning my MAF sensor and that not getting rid of the problem(threw the same codes again a month later) and the aggravating hissing noise of a roasted vacuum line was apparently present
i went hunting for vac leaks and i found it, it was a rubber hose that went from a metal line the a believe goes into the lower intake manifold and runs down the side of the wheel well and goes to this round canister thingy(for lack of a better way to describe it sorry) under where the battery is
(also the vacuum line replacement didn't fix my problem....still leaning out but has not thrown any codes yet its been at least a week all hissing noise is gone now!)
if your laying under the truck with your feet towards the rear axle and the front driver side tire is touching the right side of you body fallow the wheel well till it stops it arc towards the front bumper and flattens out there will be a flap you can pull down reveling the canister thingy im talking about(its black, green, and white on my truck)
the vacuum line i replaced(as stated above) the line itself is attached to a fitting that looks a lot like the fittings for a fuel filter (black housing and the white locking clip) it all goes onto the green part of the canister it also has the same fuel filter like fitting where it hooked to the metal line coming from in-between my upper and lower intake manifolds
i had to replace my sway bar bushings in the front and noticed something very puzzling to me....BOTH of my axle seals wear leaking...not a big deal rite? wrong i just replaced them both at the begging of june.....so i said to myself....
those axel seals r brand new....now what could be making them leak....
installation error----not a chance i did it myself(and it sure isn't my first trip to the "ok cor-all" with axle seals)
pressure build up in the front diff and the pressure going out the weakest link because my vent tub is clogged---- very high chance
so i felt around for the vent tube and found it and when i traced it to where it stopped to replace it i found out it connects to that same canister thing that my vac line was hooked up to except the vent tube is connected to the white part of the canister thing along with i believe 3 other lines of which i have not traced to see where they come from yet
now if my vent tube is clogged then the canister thing isn't supplying what its suppost to....send threw the vac line...could that be leaning out my motor? and my axle seals have no connection the the motor leaning out....
or
if the canister thing is bad then its not relieving the pressure from my front diff making the axle seals leak.....and because my canister is bad its letting the vac line just suck in air leaning the motor out?
or do you guys think its something else and these two problems are not related?
and what the heck it that white green and black canister thing there called?
thanx very much in advance
plugs are 35k old
wires are 35k old
or
