This is what my thermostat looked like when I replaced it. | Ford Explorer Forums
rizzjc
Scubajoe - Radio Mod
Staff member
Moderator
Location
NC
Garner, NC
2019 F150
Callsign
N1LVN
Well, I should know better, but after 10 years, 136,000 miles, and an P0125 code, I decided it was finally time to replace my thermostat on my Explorer. This is what it looked like:
There was a time when I thought I was pretty good about maintenance on my truck. Now I shame myself for not doing the simple stuff sooner. I promise to be better. ;)
Don't apologize to us, apologize to your poor truck. :D
She's payed me back with many a cracked nuckle over the years. ;)
Ummm, I'd have to say yes. Not sure, but I noticed this little piece mounted in the side of it which looked like it had a ball bearing in it. Would that be it? The new one did not have this. Why?
Ummm, no. Now you're getting me worried. What's it "checking"?
It's nothing to worry about. Some thermostats have that hole to allow extra coolant to flow while its in the closed position. The ball is there to allow coolant to flow in one direction, and block any reverse flow.
Yeah, I asked my buddy and he said that there may be just the ball. I noticed that the new one did not have this. You had me worried, but all is good now ... as soon as I get the new bypass hose installed, and fire it up! I just replaced the fluid, and flushed it a short time ago, but I notice there is still a lot of sludge that didn't get flushed out, so it looks like I'll be doing it again soon. I guess the 5.0 has a drain plug in the block, so I'll have to find that that next time I flush it.
You have to remove the thermostat housing to replace the thermostat. Install a new gasket, and thermostat. Make sure that you refill the system with the proper level of coolant when you are finished. That is the whole procedure.
Just be glad your thermostat didn't fall apart and go into your cooling system
-Drew
Yeah, that was good. Just another thing to add to the list of things to do to keep on top of maintenance, if I want this thing to go 200k!
