LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
Hello,
Well I just spent literally 3 hours trying to get the installation of my power steering pump completed. I have the pump installed on the bracket with the lower bolt and upper two studs attached. The two ground wires are installed over the studs with M8 flange nuts. The bracket is mounted to the stud nearer to the middle of the engine with another ground on that stud. The reservoir is attached to the bracket and the large hose from the reservoir is connected to the pump. All that remains is the attach the pressure hose to the pump. No matter how many hours I spent trying, I just can't get the threads to catch.
Just to review, I test fit everything before I started. The male fitting on the pressure hose does thread into the pump and I verified the direction I have to turn the fitting to tighten it. I have tried from the engine bay, from underneath, and from the drivers wheel well and I just can't get it connected. Some of the issue is that it is hard to hold the fitting in place and turn it at the same time, which is sort of a necessary combination of actions. I found that using a small crescent wrench was the best option as both my 18mm box wrench and 18mm line wrench are too big to maneuver in the space and won't be helpful for anything but a final tightening.
To say that this is a stupid design is an understatement, but I assume that everyone who has worked on this already knows that. To put one of the mount bolts and the pressure hose fitting in exactly the same spot is unbelievably idiotic, even for auto engineers. That doesn't even address the 20-25 minutes that are required to press off the pulley, so you can remove the pressure hose, so you can remove the mount bolt. There isn't enough room on a huge v8 engine to have these components distant enough that you can work on them separately?
I tried to slide the lower mount bolt into the pump, connect the hose, and then get the bracket mounted. That doesn't work either, there just isn't room to turn the bolt and get it into the engine. I have unbolted all of the hose brackets to that I have plenty of slack to work with.
I just got too tired to keep going so I will try again tomorrow. Any suggestions would be very much appreciated.
LMHmedchem
LMHmedchem
