Throttle body to intake manifold gasket. | Ford Explorer Forums
rs2k
Wichita, KS
2014 Ram 1500 Laramie
Is there any reason I can't use normal gasket material for this area? I have a whole roll ready to go and the gasket set I bought doesn't contain the gasket I need. The gasket that came off had several holes like it was designed for more than one vehicle.
http://i.imgur.com/e1zrrOG.jpg
My plan is to use the gasket material and cut out a simple rounded square with a big hole in the middle. :D
Like this:
http://i.imgur.com/VhjNP2k.jpg
I'll be using Permatex #3 aviation form-a-gasket on the gasket.
I would say go for it however, the replacement gasket is at auto parts stores for about $2.
i see no reason you can't make a t/b gasket.
tip: when making gaskets i use my 1/4" drive sockets, an extension and a hammer on a smooth surface to make the bolt holes.
One good reason to make one: Local auto parts store is out of stock. I just finished cutting it out. Time to put Koda2000's tip to use now. :D
