backbeat
- June 15, 2014
- Strasburg Ohio
- 1994 Areostar
My check engine codes say the tps voltage is too high. I checked the tps and the signal voltage is 3 volts at idle up to about 4.3 at full thottle. What little I can find on other vidies and such iis the voltage should be .93 to 4.5 and you adjust it for .93 with the throttle close. None of this infor was shown on a pre ODB2 Arrostar. Mine is a 94 3.0. So I think the TPS is bad. Big question though is my Haynes manual says that a quallified repair shop should replace it because it takes special ecuipment to calibrate it. Does anyone have experiance In this.
Also thanks for welcoming me Rick.
