thump thump oh hell please help | Ford Explorer Forums
93SPORTIOWA
SIOUX CITY IOWA
93 SPORT
ok i need to figure this out i dont want to just start replacing stuff when ever i het a bump at about any speed i get a thump in the front drivers side area and anmost like the truck dives into the bump ive looked at my shocks and it looks to be about full compressed maybe an inch and a half of motion that it can go and the bump stop is hitting i can see where it has been is this the shocks or what it is driving me nuts please help im begging
Sounds like your radius arm bushing is going out or your coil has popped out of its seat. Check the coil, then move more towards the radius arm bushings.
hmmm
the coil is fine and if the radius arm bushing were bad would my shock be compressed and the bumpstop hitting?
Im not quite sure if I understand fully. Fill me in a we may get the ball going.
my shock on the drivers side just sitting in the driveway looks to be almost fully compressed maybe an 1 and a 1/2 of travel left by looking at it i can see where the bumpstop has been coming into contact with the axle houseing only on the drivers side i think my shock is weak and allowing to much downward travel on the drivers side they are high mile rancho rs5000s does that sound stupid or could it be that i dont want to just replace stuff that isnt needed
Yes that can happen from a bad shock. I would try replacing that one shock to see if that fixes the problem, if it does go ahead and replace the other three. You may want to try some edels. Those are some great shocks.
