Thump ? | Ford Explorer Forums
Thump ?
Brian VT
vt
'96 XLT
Sorry. I'm a newbie. I searched some but came up empty.
'96 XLT 4.0
It makes a FOOMPF sound.
The best way I can describe it is imagine you had a 3/8" rope tied to the underside of the car and drove off. When you reach the end of the rope it would snap, making the noise and giving the car a slight jolt.
It kinda seems like a misfire (wife's theory) but my mechanic says no. At lower speeds I can sometimes detect a slightly metalic note to the sound so maybe I've got a drivetrain issue but that tone could just be from a loose heat shield ?
It happens randomly. I'm not able to make it happen. Sometimes not for 10 minutes. More often (less than 30 seconds) on slight inclines. Never when hard on the gas. Never when coasting.
It has the switch for AUTO,4WD,4LOW. No 2WD. I've run it in all modes and even driven in reverse in case that is still needed to release the hub locks ? Tranny oil and filter were changed 10K miles ago.
Tonight I did the brown wire mod thinking that maybe the transfer case clutch was the culprit. Nope, but I'm happy to be rid of the Auto function !
Any/all theorys appreciated. My mechanic says his best guess is a new transfer case, but it'd be a $1500 guess.
Edit:
Shoot. My 2nd post and put it in the wrong forum (for my '96).
Mod. help ?
