tip of the day on belts | Ford Explorer Forums
mcgyver ky
ky where all the mud is
91ford exporer eddiebauer
have you lost a belt or need to replace one dont just do one do them all that way when you need belts again you know you need all of them and you wont be changing belts all the time
keep the old belts in case of emergency
[ps if you havent seen the tip on crome go there and check it out you wont be sorry ]
and dont forget to check out my site and see my truck
Dead Link Removed
Aren't all Xs a single serpentine belt? Not sure.
By the way, a "." now and then would be helpful.
Keep the tips coming!
Robb
Yeah, I think Explorers are all single serp belts robb. Bronco II's had multiple belts though (on their 2.8/2.9 L engines).
well yes they are except the ones that are modified like mine but this is for other cars too i do have two explorer but i have five others that are not some other interesting facts are
Serpentine belts (flat ribbed belts), which are also called "Poly-V, Poly-Rib and Micro V" are so named because of the snake-like path they often follow around the pulleys. The flat design reduces heat buildup in the belt so the belt generally lasts longer than a comparable V-belt. A recommended replacement interval for serpentine belts suggested by one manufacturer is every 50,000 miles, or sooner if the belt has become glazed and is making noise.
