tire help needed plz | Ford Explorer Forums
ford29
Quaker street ny
94 xlt
i have a 94 xlt 4.0 4x4. The pansager side tire is cupping or fathering what will couse this. It is only one tire tires are brand new?Any help apprecated .
probably ball joints...have your front end checked and fix it, it will only destroy your tire if you continue..Better to fix the problem now and replace one tire,,,
Ball joints or loose Wheel bearings. When you jack up that tire, can you rock the tire left to right AND up and down or just up and down?
Both directions indicate a loose spindle nut or bad bearings.
Up and down only indicate bad ball joints on teh Knucle
i have not had a chance to look yet it is my mouther in laws not mine so i will let you know what i fide out this weekend
will rd bushings cause the tires to cup the werid thing is the tires i took of to replace had no wear issuses what so ever but they ran out of tread thx bobby
