I got mine from Central 4x4. I think they were about $10.00. It comes on a key ring, allows you to deflat all four tires at the same time. It is the manual method.
Take off valve cap, add deflator, manually check pressure when the pressure is where you want remove deflator, check pressure and reinstall valve cap.
I use do two tires at a time. The first time I used them when I got to the last tire it was about 10 psi. Had to air up a bit.
Oasis also makes some that are preset. Order them at 15 psi (what ever psi you want) install them by replacing whole stem. But when you want to air down just open and go they stop letting air out when they reach 15 psi. Very Nice but they also cost around $60-70 dollars.
I have Staun auto airdowns. You can set them to any psi you want them to stop at. No modifications to the valvestem needed. Screw them on, go undo the swaybar, and all the tires are down to a preset pressure when you're done Then just put them away.
