tire pressure monitor. | Ford Explorer Forums
Kurt Schnell
forest rgove or 97116
2002 eddie bauer
Does anyone know how to bypass the tire monitor system! I replaced the original wheels and tires with the ones from my 2002 Eddie Bauer, they look better and I have new Goodyears on them. The low tire symbol isn't an issue it is the "tire monitor fault" warning that blocks out the rest of information center.
Not sure on blocking it out, but you could have your TPM sensors swapped over to the new rims you are running.
I'm not sure if thee 2002 has the same type of controls as my 09 does but when my dash shows a tire pressure monitor fault, which it does from time to time,I can push the reset button on the dash and it turns off the warning and makes the information center visible again but still displays the low pressure tire symbol.
