troj84
- May 23, 2008
- Dayton, Ohio
- 2004 Explorer NBX
I have a 2004 4.0L. I have this really loud squeal/rubbing sound when driving above about 2300 rpms. Problem started when the weather got cooler. It sounds like a bad bearing sound. I have swapped out the belt tensioner, belt and idler pulley to no avail. Took the X to the stealership for their expert opinion. They changed the alternator, the tensioner and the belt. Yes 2 of those things I replaced less than 1000 miles ago. Thats another story with the dealer.... Anyway, after searching this site it appears that this could be the timing chain tensioner. I thought this problem was to be corrected in post 2002 models, am I wrong? How the heck did you get someone to diagnose this problem. Ive dumped over $700 into this problem thanks the the stealership and its not fixed. I think they just replaced parts to make money since they are hurting. I took it to a reputable independant shop and they thought it was the tranny. Not sure I agree. This noise is eally annoying, sounds like a moving piece rubbing on plastic while accelerating thru gears. Any thoughts? or should I just turn the radio up louder.
