Torque Specs needed please | Ford Explorer Forums
ccm2001
Vaughan Ontario
2003 Sport XLT
2003 Sport XLT
Need specs for the items.below
Sway bar End Links
Sway bar Bushing mounts - ordered 31mm measured at 1-1/4 "
UCA Pinch bolt
Please and thank you !!!
-CC
IMO torque specs are not needed for those things especially the end links.
What about the upper control arm bolts (washers)
UCA to frame mounting bolts shows 98 ft/lbs. above. Make sure you torque them with tires on the ground or the UCA bushings will bind.
