cobrapete
- May 17, 2006
- Tulsa OK
- '94 XLT 4WD
Okay, yesterday my check engine light came on. So I went up to O'Reilly's to use their scanner.
It threw a:
I cleared them out to make sure it wasn't because the TPS got wet or something and it threw the same codes. The only change I've seen since then is a slight loss in acceleration.
My question is would the EGR code be related to the TPS malfunctioning? I haven't had any codes thrown like this at all until yesterday, so I'm just curious if they're in some way related.
It threw a:
- 124: TP voltage was higher than expected
- 167: No Throttle Position sensor change in "goose" test (must get at least 25% rotation) - TPS
- 332: EGR did not open/respond during test or if memory code, did not open intermittently
