TPS problems | Ford Explorer Forums
TPS problems
monkeydude3
Millbrook, Illinois
2001 Explorer Sport Trac
Could my TPS be bad? I have a high idle after I apply the throttle. When it first fires up it runs fine. Idles at like 900 rpm when hot. I tested my TPS and the OHM levels stick up after opening it. I think it's bad
1994 XL 4.0L OHV 137k miles
George
dont check for OHMs, check the voltage - it should be at around .96V.
oh ok. well when we had it on the snapon scanner it was .96v
i dont know why it idles higher the hotter it gets
check for vacuum leaks. if it changes after warm-up, it may be a loose part instead of a line.
Ken.
what kind of loose part? ?? :-)
