Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
I took off the old TPS sensor that I drilled out crooked and installed last spring. I was trying to do the TPS mod but it did not work out, at any rate I installed a brand new motorcraft TPS sensor this morning and funny things are happening.
First off the idle used to be very low and weak around 400-500rpm in Drive, the idle went way up and is now around 1100rpm in drive. In park before it was around 600rpm, with the new TPS it is at 1500rpm.
The engine seems to run a lot smoother and rev faster, though at times I had the pedal almost to the floor and the truck would not down shift. Seems very strange why this would happen also the shifts are a lot snappier- like the tranny does not know when to shift. It seems as if the computer is confused as to where the throttle position is.
I wonder if the last mechanic I had work on the truck tried to turn up the idle screw or maybe I should have disconnected the battery and reset the computer before I put on the new TPS??
I am really surprised that putting on a new TPS has made so many changes- especially with the idle, what could be wrong?
Any opinions are greatly appreciated.
