Nuggethead 420
- September 2, 2003
- Milwaukee, wi
- 91 Eddie Bauer
I have just installed and put in an additionioal oil cooler for the tranny and with the slipping I had from yesterdays post with the shift solinoid I found that a plug had fallen off not the nuetral saftey switch plug there is another plug on the same side of the A4LD that will not stay in it is loose as the day is long and I cannot see why. But when I connected it it still does the same slipping and the tranny is very hot after just a 10 min. trip to the store. It slipps really bad off the line but gets up to speed pretty well.
Could the lines be blown out? they flushed o.k. but I am still alittle nervous about them due to the tranny giving me a burn trying to check the plug when I returned.
what is the plug for and when I cleaned it with contact cleaner it made no difference in the tranny slipping and shifting trouble.
More advice is needed.
Thanks in advance.
Thanks in advance.
