Does your vehicle description as 91 Explorer 2wd manual mean you have a manual transmission?
If so, you won't have a dipstick like an automatic does. With a manual trans I believe you have to get under the truck, remove the bolt in the fill hole, and use your finger in the hole to see if it's full to the bottom of the hole.
