kb1473
- December 19, 2006
- Dallas, TX
- 98 X EB
I think, based on reading a number of 'tranny problem' posts here, that I have a fairly common problem...trouble getting the trans to go into reverse, drive, etc.; failure to upshift, and so on.
Some details about the vehicle:
1998 Explorer Eddie Bauer
2WD (auto, obviously)
169,000 miles
Since I learned that doing fluid flushes too far after the recommended service points could do more harm than good, I've not done any flushes; just monitored the fluid levels. Vehicle does not appear to have any fluid leaks/consumption.
NOW--MY UNIQUE ISSUES/QUESTIONS:
After enjoying a completely trouble-free 168K miles, I sold this truck about a month ago to my sister, who needed a reliable vehicle. I thought I was doing her a favor. In my entire ownership, repairs were limited to a $3 thermostat, a $50 A/C dryer, and brake pads/rotors as needed. Nothing else.
Last week she called and reported the OD light flashing intermittently. A couple of days later, she called describing the above symptoms, asking if I'd ever had any trouble with it. Since I hadn't, everything she was describing sounded foreign to me, but sounds like symptoms I see on posts here.
My questions are:
1. Which tranny does the '98 2wd Explorer use (4-door, SOHC V6)?
2. Isn't there a gradual worsening of performance, or do these trannys go from "fully functional" to "dead" in just a single outing? I never had the slightest hint of tranny issues.
3. One thing she mentioned that i haven't seen in other posts is that the car will limp along at about 50mph for a few hundred yards before quitting again, BUT if she turns the car off and re-starts it, it'll go into gear and limp another few hundred. Does this indicate an electrical issue rather than the trans itself? She mentioned that they replaced the battery a few days ago...any way they could've messed up a control module somewhere?
I'm trying to help diagnose it from 400 miles away. Any suggestions you guys can offer would be greatly appreciated.
169,000 miles
My questions are:
