treehuger
- March 22, 1999
- Salt Lake City, Utah
- 94 xlt
At 100k my tranny started acting up. After reading many posts I inspected and cleaned the governer, etc... and though my fresh fluid seems to be reading the correct level now, Im still more or less stuck in first gear.
Actually if I slightly let of the throttle it will shift up to 2nd, occasionally it will kick back down to 1st again but not always and I can drive normally [but cautiously]? If I do not let off the throttle it continues to rev higher and higher in 1st.
This seems weird, it will shift to 2nd [ie, the transmission is capable of working] but only under these unusual conditions.
best description is having to power shift a manual trans without a clutch.
To recap...
I inspected and cleaned the gvn'r [it showed slight wear but was not stuck as others have reported]
I replaced the vacuum modulator [no fluid in the vac line]
Changed out the fluid and filter [grey sediment in pan, but no particals or metal debris]
At any rate I recently got hit by the economy cutbacks and have no job so Im very hesitant to have it rebuilt or buy a rebuilt and install myself [$$$$] given the unusual behavior Ive described.
Second opinions anyone?
Doug
BTW...Thanks Mike[NH25] for helping me through the intial troubleshooting.
To recap...
Doug
