tsilney
- July 9, 2006
- montgomery, il
- 2015 Explorer Sport
Hi,
I have a 2001 V8 AWD explorer with 112000 miles on it. Today after driving it, it was smoking. Trans fluid was all over the entire bottom of the truck. I cleaned everything and it looks like it is coming from between the trans and the transfer case.
Also, the bell housing was wet and there is a vent tube that looks like is dripping as well onto the 02 sensor. It looks like the Transfer case leaked onto the front drive shaft and is sprayed it all over.
The trans fluid and filter where changed about 7 months ago. I looked up some posts and decided to check the transfercase fluid. I opened up the fill plug and about 1.5 quarts came out on level ground. I thought the fluid should be up to the mark only? Is there a seal between the transfer case and transmission and if so is it easy to change. I am pretty mechanical. Any thoughts. Will try to get pics tomorrow when it is light out.
Thanks
Thanks
