Trans linkage help with PIC | Ford Explorer Forums
cjmedina
Central New Jersey
3 Explorers 01,99,99
I want to know how to remove this linkage from the manual control lever. do I just pry it off or is the a fastener?
I have loose linkage at the selector and trying set the linkage correctly to the lever.
It seems to be out of adjustment because it does not lock in a detent position in first gear.It feels like is has to go a little bit further.
ftp://cj136.gotdns.com/files/DSCN8176.JPG
ftp://cj136.gotdns.com/files/DSCN8177.JPG
CJ
WELL....how does it come off?
there is a sdjusting wheel under the steering column inside the truck. remove the steering column lower cover and you will find. hopefully it is not broken like mine:( you can adjust the shift lever from there
