Rayz2000Sport
- November 2, 2007
- College Dover DE,Baltimore(Essex) Maryland
- 2000 Ford Explorer Sport
Okay, if you search my posts, you will see that I have been having some tranny issues. 2000 Ford Ex Sport, Auto 4WD SOHC. The main thing is at speed, in higher gears it seems to "hesitate" and "jerk". (I have noticed that if it feels like it might start to jerk, I can let off the gas and "reaccelerate" and it seems to keep it from jerking) I also had it feel like it would not shift into a higher gear which caused the check engine light to flash a few times then go off. (only happened twice, never had the OD light flash, from what I understand this indicates a mech failure in the tranny)
This said, I am thinking about dropping the pan and changing the fluid and filter that way. I know this will not get all the fluid, but my reason for doing it this way is to see if there is any obvious problem IE parts laying the pan. Also, I will use regular old ATF, nothing fancy because if it doesnt help the problem then I am not going to have to replace a tranny full of expensive fluid.
Question is....
1. Where can I get a pan gasket?
2. Where can I get a tranny filter?
3. I am sure there are all sorts of things I am over looking, please do tell!!!
Any help will be greatly appreciated, I have a GF that lives in PA and I am in MD. Catching some crap over her always having to visit me because the truck is not running right!! Hoping I can "fix" the problem or find out what is going on.
Please, Any Help Is Greatly Appreciated!!!!
Kyle
Question is....
Kyle
