masospaghetti
Just sayin before you jump into things - seriously
First Off & BTW - for our information; how many miles on the rebuild since installation?
1-2 & 2-3 Notchiness: Invest $18 and drain/refill with Valvoline Full Synthetic ATF as I previously recommended in this thread.
REASON: I'm sure that you have a lot of steel bearing break in material and brass synchro material floating around in there.
NOTE: the replacement rebuild Bearings & Synchros are made in CHINA as opposed to the Mazda OEM finely machined Japanese sourced parts.
2-3 Shift Grind: This could quite possibly be the need to bleed the Slave Cylinder.
I've had this happen to me a few times and it alerts me it's time to bleed the hydraulic system.
I generally do it at 30,000 miles, at the same time I change the Transmission and Transfer Case ATF Fluid.
Invest in a Harbor Freight Hand Vacuum Pump ($20) and
bled the slave cylinder that is located "conveniently" within the transmission.
To accomplish this, there is a bleed nipple on the drivers side of the bellhousing - 3/8" if I remember correctly.
Use the box end of the 3/8" wrench, AND
you might have to grind the "box" end down thin so as to be able to have the CLEAR Vinyl bleed hose down as far as possible on the bleed nipple so as to attain suction with no air leak.
Use a quality brake fluid such as Valvoline Dot 3/4 - $7 to $8 a Quart at Pep Boys.
My Bleed Procedure: Make sure to suck out most of the the OLD fluid from the Master Cylinder.
Fill up with new Valvoline Dot 3/4 Brake Fluid - leave Master Cylinder Cap on BUT loose.
Go underneath, open up bleed nipple, suck away with HF Vacuum Pump.
DO NOT let Master Cylinder go dry, refill, and repeat a few times to ensure you get all the old brake fluid out of the system.
Every once in awhile during the bleed procedure, get in the cab, and CAREFULLY pump the clutch pedal a few times.
Dump old brake fluid in a clear plastic milk jug and be amazed at the color change as well as all the crap floating around in it...
Last but not least.
The two different guys, professional mechanics with VEHICLE LIFTS and HYDRAULIC TRANSMISSION JACKS THAT REACH UP 7 FEET, that I contracted to replace my clutch twice for $500 flat rate labor (using my sourced materials - all LUK brand - flywheel, clutch disc, throwout bearing, pilot bearing, slave cylinder) BOTH commented when I picked up my Ex how
Absolutely Frickin' Heavy the Trans Assembly was, AND
what a BEAR it was to pull the Trans Assembly off of the Engine AS WELL AS reinstall the Trans Assembly to the engine.
Convinced that in 14 years of ownership, 214,000 Miles and counting, each time that was the
Best $500 "outsourcing money" I spent - You've been warned
Hope all that helps and guides you to your final decision.
