YeloPony
- February 20, 2010
- Central PA
- 07 Sport Trac Limited 4x4
So my 07 Limited 4x4 has 93k on it, everything is fine, except around 45 and 60 it seems like the tranny can't make up it's mind and there a little slipping back and fourth, at least that's what it feels like... only under light acceleration, if I give it gas it's fine, if I turn off the OD it doesn't have an issue (thought it does **** quite hard with the OD off).
I had the garage check it when I did a tire rotation and they found nothing wrong (fluid is fine, no codes) but suggested I take it to a transmission specialist.
I'm wondering if there is a known issue that I could be dealing with?
